Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Prandlt-Glaubert singularity
Old   December 10, 2016, 06:03
Question Prandlt-Glaubert singularity
Martin
Martin007 is on a distinguished road
Hello everyone,
I would like to study a Prandlt-Glaubert singularity on a jet fighter.
I have a problem with my solution since I don't visualize any liquid water. Furthermore the pressure, the velocity and the density are constant in all my enclosure box.(the liquid generation rate is not constant but the fraction liquid is constant.)
Here are my settings :
density based
steady
multi phase => Wet steam (I have no choice since density based). How can I choose the humidity percentage of the air inside the enclosure ?
Turbulent => K-epsilon
Operating condition : P=100965 Pa
Pressure inlet :
Total gauge pressure= 100965 Pa
Supersonic= 6300 Pa
=> v=330m/s
Pressure Outlet :
I think that my issue is due to the Wet Steam option because I did not set a humidity rate.
Can I use an invicid model instead of a turbulent model for this case?
Also I would have liked to see simulate this singularity with a transient simulation and a pressure fonction depending on time in order to simulate an acceleration of the plane from Mach=0.7 to Mach=1.2 for example. Should I use a user define fonction ?
Thank you very much in advance for your answer.
Sincerely.
Martin007 is offline   Reply With Quote
aircraft, airflow, compressible, density based, wet steam condensation
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
solution singularity litonx OpenFOAM Running, Solving & CFD 1 February 21, 2007 02:32
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 12:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 12:08
