Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
DPM Modeling problems
Old   November 1, 2016, 09:26
Post DPM Modeling problems
Utsav Jain
utsavac is on a distinguished road
Hello guys,
So I am doing a steady state combustion simulation with liquid and atomized fuel. This is how I am proceeding:
1. I run the non-reactive case to get a stable solution making sure that my mesh is correct or fine enough.
2. After I get a steady non-reactive contours, I switch on the combustion and then run iterations to get a steady contour for reactive scalars.
3. Once I get a steady and converged solution for reactive scalar, I switch on the DPM model and inject particles from the inlet surface. When I do this, the entire domain becomes unsteady and I never get a converged solution. By not getting converged solution I mean that the residuals keep oscillating (which maynot be a problem as they oscillate in my second step as well) but the mass flow at the exit also oscillates and doesn't come to a constant value.
I am not able to understand the problem? As my flow is not getting converged, even after a large number of iterations with DPM modeling switch on, I don't get proper contours as a result of which the particle evaporation doesn't take place at the right place in the domain and some particles remain incomplete because of lack of evaporation.
I am not sure if the mesh is the problem or any other thing. I will be thankful if anyone can help with the problem. There are a lot of details associated with the simulation so let me know and I will give you more details. For now I am running a steady state problem.
Also I am not switching on the unsteady tracking of particle. I also wanted to know how my solution will be affected or what is the different between switch on the unsteady particle tracking and what I am doing?
utsavac is offline   Reply With Quote
convergence, dpm, fluent, steady simulation
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
modeling counter current flow in DPM Eloise.rhm FLUENT 0 February 26, 2015 05:43
Short course: Modeling of Water Resources and Environmental Problems using OpenFOAM liu OpenFOAM Announcements from Other Sources 0 March 14, 2012 17:32
Aeroacoustic Problem (Modeling Flow-Induced Noise Problems Using FLUENT) cici Main CFD Forum 0 September 29, 2011 15:28
DPM problems hendar_k FLUENT 2 May 22, 2011 23:15
