October 24, 2016, 07:43 |
divergence in two phase flow
Nguyen Duy Trong
Rep Power: 12 |
Hi everyone,
It is appreciated if some one could help me on this problem, Recently, I am using Ansys Fluent to do simulation of flow fields around a simple rectangular box with bottom of box is assumed on a flat plat. I specify the inlet with pressure inlet and the outlet with pressure outlet, the other domains are set by wall. The VOF method is used with Open Channel Flow is selected. The assumed velocity is 2 m/s, minimal spacing from box is 0.01 (m). The problem is set run with transient condition and time stepping dt is set at 0.001. My simulation run well with 100 first iterations, however, it appears suddenly with AMG solver divergence for pressure correction despite of the fact that residual of flow variables is decreasing and floating points. I really do not know what is the reason for this error, could someone help me to make clear it. Thank you very much, |
November 1, 2016, 03:08 |
Rep Power: 13 |
post pictures of setup, geometry and divergence
amg divergence, fluent, pressure correction |
Discrete Phase Model, outlet mass flow rate does not fit | edu_aero | FLUENT | 29 | February 3, 2020 09:38 |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 18:02 |
Difference in flow distribution of single phase and multiphase analysis | shivasluzz | CFX | 0 | April 22, 2015 23:54 |
How to go about modeling injection nozzle two phase flow in FLUENT? | skonda2 | Fluent Multiphase | 0 | March 17, 2015 08:52 |
low speed compressible two phase flow?? | cat | CFX | 0 | November 15, 2005 08:59 |
