Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Heat pipe wickless-simulation on Fluent-Multiphase
Like Tree6Likes
Old   September 29, 2018, 16:38
Tonoy Mondol
Tonoy Mondol is on a distinguished road
Originally Posted by Repudaman View Post
Please someone upload the mesh file for the heat pipe (2D). I am not able to separate the water and vapor regions and also condenser adibatic and evaporator region.
hello are you going to use udf? or evaporation condensation lee model which is built in
Repudaman likes this.
Tonoy Mondol is offline   Reply With Quote
Old   September 30, 2018, 03:11
Default The UDF is not worling in ansys 14,15,16,16.2
  #22
Repudaman Singh Sandhu
Repudaman is on a distinguished road
Sir I have uploaded the udf posted in this page for 2 d heat pipe evaporation condensation. But the error comes that some step in udf is not define in the command window. Please suggest me what to do in this case. And kindly suggest me that How much watt (heat flux) should be added in the evaporation wall section for evaporation process and on the other hand what should be boundary condition for condenser wall so that vapor converts to the liquid.
Thanks
Repudaman is offline   Reply With Quote
Old   September 30, 2018, 03:16
yes. But the udf uploaded in the post is not working in the fluent.
Old   October 3, 2018, 09:41
Default continuity residual not converging
  #24
ASHUTOSH KUMAWAT
ASHU_VED is on a distinguished road
Originally Posted by Abdelhamid Kassem View Post
Find attached the UDF i used for my simulation on Ansys 15 and ansys 17 because, ansys 16 doesnot work with me. It has a bug regarding this UDF.
It takes some time and many trials for simulating the HP. My advice is to start with 2D simple case and then introduce complexity with time. You will need to simulate the boiling tutorial to get some experience about this kind of simulations.
For simulating the condensation, you will need to generate fine wall layers for catching the condensation droplets.
For simulating the Heat pipe you can use these useful tutorials:
1-https://www.researchgate.net/profile...g+Tutorial.pdf
2-https://youtu.be/hPeGvczYHMM
3- https://youtu.be/LQ2y0sIXgio
4 -article: CFD modeling of flow and heat transfer in a thermosyphon
Asghar Alizadehdakhel , Masoud Rahimi , Ammar Abdulaziz Alsairafi
5 -article-2:Three-dimensional CFD simulation of geyser
boiling in a two-phase closed thermosyphon - Hussam Jouhara a,c,*, Bandar Fadhl b,c, Luiz C. Wrobel
If anyone have a question please, write it here so every one can see it and i will reply.
Thanks and good luck
hello
i have some doubts
(a) in mesh, what should be done with boundary in fluid region? is there any boundary condition in that region? if possible please upload mesh file.
(b) udf should used alone or with lee model.
i am not getting convergence in continuity. the residual is reaching to e-4 limit.
ASHU_VED is offline   Reply With Quote
Old   April 7, 2019, 23:26
tao
qimao is on a distinguished road
Thread closed.
I succeeded in simulation of a 2d heat pipe using fluent 17 VOF multiphase model with hooking UDF with the case.
The UDF didn't work on Ansys 16 due to some bug in the program, so you should use ANSYS 15 or 17 instead.
If someone need help in the simulation, write your email and i will send some good resources.
Hi, Could you please send me details to qimao520521@gmail.com
Thank you
qimao is offline   Reply With Quote
Old   May 14, 2019, 02:50
Default thermo syphon
  #26
behnamrha
behnamrha is on a distinguished road
hi
i wanna simulate a thermosyphon in lee model.
i need your help.
i have some problem in initialize and mass transfer.
thanks for your atnettion and answer.
email: behnamrha89@gamil.com
behnamrha is offline   Reply With Quote
Old   May 14, 2019, 03:02
behnamrha
Hi
i use Lee model .
what is use for these UDF?
and where should i use it ??
thanke you
Old   June 8, 2019, 02:02
Smile CFD analysis of heat pipe
  #28
LINTO P ANTO
linto is on a distinguished road
Sir,
I am trying to do CFD analysis of wickless heat pipe. But not able to fill perticular amount of fluid in heatpipe. What command I have to use to fill 10% of volume of water in the heat pipe using fluent? if possible can you share your contact no please..
linto is offline   Reply With Quote
Old   June 8, 2019, 06:56
LINTO P ANTO
Sir,
Old   September 30, 2019, 07:29
Ketan Warghat
Ketan K2 is on a distinguished road
Thread closed.
please mail me the related resourse @ketan.v.warghat@gmail.com
Ketan K2 is offline   Reply With Quote
Old   April 1, 2020, 08:58
Wyj
李正
Wyj is on a distinguished road
Does your heat pipe simulation model have porous media?
Wyj is offline   Reply With Quote
Old   April 1, 2020, 09:06
Post
  #32
Wyj
李正
Thread closed.
Is there a porous medium in your heat pipe model
Old   December 23, 2021, 00:48
mohsen
mohsensalehi1993 is on a distinguished road
Refer to this address:
https://fluentcfd.ir/webinar-ansys-fluent/
mohsensalehi1993 is offline   Reply With Quote
fluent - udf, heatpipe, multiphase, vof
K80 For MultiPhase Flow Simulation in Fluent HyperNova Hardware 1 January 27, 2016 06:53
Multiphase VOF simulation and also Solid Fluid Heat Trasfer gerardosrez Fluent Multiphase 0 November 11, 2014 15:31
Heat pipe simulation nazanin fazeli Fluent Multiphase 0 February 3, 2014 08:13
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
the simulation of the heat pipe Crystal FLUENT 0 June 21, 2008 11:38
