Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Multiple Reference Frame around an impeller
Old   October 18, 2016, 08:38
Default Multiple Reference Frame around an impeller
Ravi
Spark is on a distinguished road
If I am considering a single impeller a cylinder around the impeller is considered for applying moving reference frame. Suppose now if I have 2 impellers on a single shaft, should I consider 2 separate cylinders enclosing the impellers or a single cylinder enclosing both the impellers?
Kindly help me out with this.
Thanks and regards.
Spark is offline   Reply With Quote
Old   October 24, 2016, 05:04
Cees Haringa
CeesH is on a distinguished road
You could do both, and probably it won't make much of a difference.
There was some study published in conference proceedings, I believe in the proceedings of the 10th european mixing forum in 2000, held in Delft. (can't find the book anymore since I moved office unfortunately), by Oshinowo if I'm correct. He claimed keeping the MRF-rotorzone relatively small yielded slightly more reliable results (smaller being approx 1.5x the impeller radius, with a zone height of approx. the impeller diamater).
Personally, I typically follow this guideline, even with a slightly more shallow zone sometimes. (+/- 1.5 blade height). Of course, it also depends on the inter-impeller spacing. If that is less than 1 impeller diameter, I typically put them in 1 rotating frame.
Hope this helps!
Cees
CeesH is offline   Reply With Quote
LEMOS InflowGenerator r_gordon OpenFOAM Running, Solving & CFD 103 December 18, 2018 01:58
OpenFOAM 1.6 ext - Compilation errors - Fedora 17(32bit) toolpost OpenFOAM Installation 15 September 21, 2012 10:38
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Multiple reference frame Boundaries H.A.S FLUENT 0 April 3, 2007 13:45
Building OpenFoAm on SGI Altix 64bits anne OpenFOAM Installation 8 June 15, 2006 10:27
