September 30, 2016, 07:00 |
VOF operating conditions for buoyant liquids
Ignacio
Rep Power: 13 |
I would like to ask for advice for the following VOF simulation I have a liquid pool with a gas space above. All boundaries are walls except the ceiling, which is a pressure outlet. Fluent recommends to use the following operating conditions with VOF Location: Gas space Ref density: Lightest phase (air) This leads to a zero pressure in the gas space, which minimizes the round-off errors and improves the convergence of the simulation. All good. However! In my case, I am interested to resolve accurately the body forces in the liquid. Using Fluent recommendations leads to low round-off errors for the gas pressure, but large round-off errors for the buoyancy in the liquid. The results were actually quite bad when using these recommendations. Thus, I switched to the following operating conditions Location: Pool surface Ref density: Liquid Using those conditions the pool behavior is well predicted, but the convergence of the simulation is quite bad due to the high pressures in the gas space. What it then the best approach to have 1) Accurate body forces in the liquid?, and 2) Good overall convergence? Any suggestion will be appreciated =) Ignacio |
Operating Conditions (( Gravity )) | Heat Pipe | FLUENT | 5 | May 25, 2014 05:18 |
Boundary Conditions in a cylindrical system (VOF) | Jan90 | Fluent Multiphase | 0 | April 7, 2014 13:35 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
Moving mesh or VOF? | Giovanni | Main CFD Forum | 16 | September 24, 2001 09:25 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 19:29 |
