Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
open channel mix
Old   September 25, 2016, 09:06
Question open channel mix
miguel
xaxoo is on a distinguished road
Hi I am traing to simulate fiber impregnation.
when I used
- General transient
- Model - Multiphase/ volume fluid- implicit
I define liquid 1º phase
wood 2º phase
-Ccell zone condition -> porous zone
- B.C -> inlet velocity_-> I insert the velocity
V.f. wood=0
pressure outlet solid volume fraction =1
- Reference values compute from inlet
reference surface body
- Inizialization
compute from inlet
fiber volume fraction =1
If i do it like that the system work and i obtained the result i expected but, If I use
- General transient
gravity (change)
- Model - Multiphase/volume fluid- implicit
open chanel flow
open chanel wave BC
I define wood 1º phase
liquid 2º phase (change) -> As explained in the manual
open chanle option (change)
multhiphase liquid for inlet phase
wave to none
free surface to -0.02 because the origin (and also bottom) is at 0 m and the free surface is under it.
I have also tried with open channel (change)
from neightboury cell defining bottom at 0m
- Inizialization
compute from inlet
flat
liquid fraction =1,0 i have tried both
I never have the flow from the inlet of the liquid and in the result wood volume fraction is constant along the surface. WHY? I FOLLOW THE MANUAL INSTRUCTION, but it does not work.
The second question is if I want to move the porous media while the flow is camming from the inlet, shall I use the mixture mode? or i can do it with volume fluid
Thank you in advance
xaxoo is offline   Reply With Quote
open channel, porous media
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 16:14
Yacht in Open Channel Flow andreimour FLUENT 1 October 15, 2010 00:54
