SEPARATE VELOCITY value FOR TWO PHASES in "VOF |
September 7, 2016, 14:15 |
ANKUR GUPTA
Rep Power: 10 |
HEY ALL FLUENT GENIUS'S....
I have a small question... I am simulating the flow around ship-hull and want to see the effect of high-speed wind on the drag of the hull and on the wave elevation. I have done a primary simulation, giving pressure inlet boundary condition and defining the free surface. Is it possible to give separate velocity value for both faces let's say "x " for water and "y" for air???? Please help me in this ..... |
October 7, 2016, 03:05 |
Rep Power: 11 |
a bit late, but in VOF there is only one momentum equation for all phases
in fact, technically there aren't two phases, it's one phase with local variations of properties what you want to do is not possible within the framework of VOF |
multiphaseEulerFoam: PtrDictionary<phaseModel> phases_ of multiphasesystem fluid | maybee | OpenFOAM Programming & Development | 9 | January 27, 2014 07:24 |
help with UDF for contact angle based on contact line velocity | gandesk | Fluent UDF and Scheme Programming | 14 | October 29, 2012 14:58 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
Velocity Under-relaxation in SIMPLE type methods | Matt U. | Main CFD Forum | 6 | July 4, 2005 06:29 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
