Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
use mixture model to simulate two-phase flow with phase change
Old   September 7, 2016, 12:38
Default use mixture model to simulate two-phase flow with phase change
dxm2008 is on a distinguished road
hello, friends
I am trying to simulate a water flow along a 2*2 rod bundle inside a square channel with a constant heat flux at the rod surfaces. phase change will happen in the process. below is my setting:
mixture model and turn on the slip velocity and implicit body force.
energy: a cosine chop heat flux which is at the rod surface.
realizable k-epsilon model with standard wall functions.
i use UDF to model the mass and energy transfer between the water and vapor phase which works well. it works as several source terms.
in the operating conditions, pressure is 0, and give a specified density which is the density of vapor
the solution method is SIMPLEC, pressure is standard, momentum, k and energy is third muscle, volume fraction and epsilon is QUICK.
the factor for p is 0.3, for momentum is 0.5, for k is 0.5, for epsilon is 0.8, for energy is 0.98, the others are default.
result is: it can run for hundreds of steps, but always gain divergence after that.
so could you guys give some suggestions for the next step? or did I make any mistakes in the settings.
dxm2008 is offline   Reply With Quote
Old   September 7, 2016, 12:56
stalukar
shaonme is on a distinguished road
Mixture model does not work with heat flux.
It should be setup with temp difference.
You must specify a temp diff between wall surface and cell temp.
shaonme is offline   Reply With Quote
Old   September 7, 2016, 13:04
thank you for your reply, here are more results about temperature. it has six spacer grids, so some temperature reach a little higher.
Old   September 7, 2016, 13:06
I only know the power of the rods, so it is hard to give a accurate temperature difference. heat flux is power/area
Old   September 7, 2016, 14:13
stalukar
Have u found any phase change around the pipe (I mean at a distance from inlet)? If yes, then is it increasing?
Old   September 7, 2016, 15:15
yes, phase change has happened, but not very good, I have some results but which is divergence. see pictures.
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 09:38
UDF for modifying density of mixture phase during the calculating process sola86 Fluent UDF and Scheme Programming 2 May 28, 2019 10:24
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
How to model the solid-fluid phase change in CFX ohrmond CFX 2 May 26, 2006 07:27
