Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Error in multiphase model, after running case for 300 time steps.
Old   September 1, 2016, 19:41
Default Error in multiphase model, after running case for 300 time steps.
Ash Kotwal
Ash Kot is on a distinguished road
I'm running 2 phase flow implicit Eularian-Eularian flow model.
created model.
defined material to each phase.
defined boundary conditions-for inlet, it's mass flow rate with initial gauge pressure defined
defined outlet pressure boundary condition- as outlet pressure values.
Then velocity slip ratio defined based on variable mass flow rate of phase 1 but constant mass flow rate of phase 2.
All above boundary conditions are defined as profile UDFs as function of flow time.
then phase coupled simple solver is used.
rest is just a calculations activities, with surface monitors.
the case successfully setup and started calculations till 300 time steps with 1 second as time step size.
after that UDF, as function of time, provides new values to the solver. and that's where everything goes wrong and suddenly I receive divergence in AMG solver. Which I shouldn't be getting since the case ran successfully for first 300 time steps
so I need help to know what exactly went wrong.
thank you,
regards,
Ash Kot is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
