Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
how can i calculate vapor quality?
Old   July 30, 2016, 13:28
Default how can i calculate vapor quality?
P_VS is on a distinguished road
Hello!
Is there a way of calculating vapor quality or vapor mass fraction in Fluent or CFD post?
I am able to calculate vapor volume fraction but i can't see a way of computing the mass fraction.
Thank you!
P_VS is offline   Reply With Quote
Old   August 22, 2016, 14:48
Real Name :)
ComputerGuy is on a distinguished road
Vapor mass fraction is found by bringing density into the equation:
Vapor Mass Fraction= \frac{ \rho _{vapor} * vol frac vapor}{\rho _{vapor} * vol frac vapor+\rho _{everything else} *(1- vol frac vapor)}
Of course, "rho everything else" is just a shortcut, as is the (1-vol frac vapor). You'll need to multiply every phase's density by its volume fraction, such that you have N terms in the denominator for an N-phase system.
ComputerGuy is offline   Reply With Quote
calculate velocity difference helly OpenFOAM Post-Processing 0 June 21, 2016 09:49
is it possible to calculate circulation for this image Roule Tecplot 0 March 10, 2016 05:16
Error occurred during calculate mass flux aronsyu Fluent UDF and Scheme Programming 0 December 28, 2015 08:16
calculate values for eps and k from Re or u????? sbar OpenFOAM Pre-Processing 5 August 16, 2010 05:10
How to calculate Torque for francis turbine manish CFX 4 March 15, 2007 03:57
