Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Three phase modelling
Old   July 25, 2016, 08:49
Default Three phase modelling
Richard
richard222 is on a distinguished road
I am trying to model a bubble column consisting of water as the liquid phase with a oil layer on top, and air injection through a nozzle at the bottom of the column .
I started with a two phase (air-water) bubble column using the Eulerian method and this works well, but when I try to add a third phase for the oil layer it requires me to define a diameter and treats it like another gas phase. Is there another way in which I can include the oil phase in Fluent?
Thanks, Richard
richard222 is offline   Reply With Quote
Old   February 3, 2017, 05:49
Odonata is on a distinguished road
Hello Richard,
I have similar problem. I'm trying to simulate two continuous phases and one dispersed. No success so far. Did you figure it out?
Kind regards,
Marta
Odonata is offline   Reply With Quote
Old   February 3, 2017, 07:07
Richard
The Eulerian method only allows a maximum of one continous phase. All other phases need to have a diameter specified. So you can create 1 continous and 2 extra phases, but you would need to define an arbitrary diameter for one of your continous phases. Alternatively, you can convert the continous phase into a mixture phase by specifying two materials . However, there will be no interfacial forces between these two materials since they are part of the same phase
Old   February 3, 2017, 07:46
Thank you for reply.
I tried to "artificially" add dispersed phase to VOF model but i can't get no further than 1 sec of model time.
I thought about UDF, but that will require learning of writing codes...
Have you modeled with arbitrary diameter for one of phases?
Old   February 3, 2017, 08:43
Richard
Yes I can simulate an extra liquid phase with an arbitrary diameter
Old   May 22, 2017, 18:50
Julio Herrera Venegas
julioHV is on a distinguished road
Hi guys,
Actually, i am facing a similar problem. I need fill a confined space whit slurry (copper concentrate). My strategie is have two continuos phases (air + water) and one discrete phase (copper particle). However, i have divergence problems whit the simulation. Any idea how can i do this simulation? In specific, i cant set the volumetric fraction of discrete phase, even if i active the granular model for the discrete phase.
Sorry for my bad english, is not my natural lenguage.
julioHV is offline   Reply With Quote
bubble column, eulerian, fluent, multiphase, secondary phase
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam xpqiu OpenFOAM Community Contributions 8 June 17, 2015 03:08
Spray Modelling within the Discrete Phase model Jufri FLUENT 2 March 18, 2015 05:17
Discrete Phase Modelling in Fluent gill11a FLUENT 2 March 8, 2015 19:56
three phase modelling (air sand water ) Gunjan kumar FLUENT 0 December 29, 2004 08:55
Two phase modelling Mamdud Hossain FLUENT 1 August 19, 2003 04:04
