heat flux not generation at article is to be dried |
July 14, 2016, 11:17 |
rpshastri
Dear sir , here i am modeling a convective drying process of a pellet(made up of ball of iron ore fines and moisture(water)) by using Fluent 2d,dp.pbns,eulerian,sstkw,transient ,my main problem is this heat is not transfering inside the pellet which is tobe dried .
why heat and mass transfer not occuring while temperature variation in suurounding and pellet is showing in contour but contour of volume fraction of liquid/vapor in showing zero means no variation on graph plot. plz help me if any one have command you may charge i will pay if problem is resolved . RP Shastri 7389929899/7895769171 rprasadrose@gmail.com |
heat and mass transfer, not occuring in pellet |
Monitor Heat Flux in CFD-Pre | cltormar | CFX | 5 | November 20, 2014 12:45 |
Heat Generation rate in W/m³ | ashghan | OpenFOAM Programming & Development | 0 | June 27, 2014 06:42 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
How to define the heat flux in the interior interface between two phases | fangdian | FLUENT | 1 | November 18, 2013 08:23 |
Heat Flux Wall Boundary Confusion. | Joee | FLUENT | 1 | August 21, 2010 13:20 |
