How can I avoid Divergence when simulating a boiling flux in FLUENT |
July 14, 2016, 09:59 |
Rep Power: 11 |
Hello! I am trying to simulate in FLUENT a boiling flux through a vertical channel, but it keeps giving the next message:
# Divergence detected in AMG solver: vof-1 -> Increasing relaxation sweeps! # You may try the enhanced divergence recovery with (rpsetvar 'amg/protective-enhanced? #t) turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 101698 cells reversed flow in 88 faces on pressure-outlet 6. Divergence detected in AMG solver: vof-1 Divergence detected in AMG solver: vof-1 Divergence detected in AMG solver: vof-1 Error at host: floating point exception Error at Node 0: floating point exception Error at Node 1: floating point exception Error at Node 2: floating point exception Error: floating point exception Error Object: #f My BCs are: velocity inlet (with a defined profile), pressure outlet and Wall (temperature). Temperature of vapor is fixed to saturation temperature. I have tried both SIMPLE and COUPLE methods, and tried reducing the under relaxation factors. Still, divergence is detected after a few iterations. Could it be due to the choice of phase interaction methods? I don't know what else I can try. Any advice will be apreciated. |
Udf for moving heat flux in 2D cylindrical geometry | devia21 | Fluent UDF and Scheme Programming | 0 | April 20, 2015 01:27 |
divergence + define_uds_flux + axisymmetric flow | bharat.cmeri | Fluent UDF and Scheme Programming | 0 | September 5, 2014 03:29 |
how to solve AMG Divergence in fluent? | javad2140 | FLUENT | 0 | August 27, 2014 04:42 |
Systematic FLUENT AMG DIVERGENCE with Delaunay Mesh | benjamin_ | FLUENT | 0 | July 24, 2014 08:26 |
How to avoid Divergence of multiphase (gas/liquid system) in Fluent :??? | mounir | Main CFD Forum | 1 | September 1, 1999 17:30 |
