July 5, 2016, 02:54 |
Calculating flow rate -DPM
Dhayananth
Rep Power: 12 |
Hi all,
My model is having two inlets and two outlets as shown in figure. I am injecting massless particles at the inlet1. Using the particle trajectory of particles I want to calculate the fraction of flow through each outlet which is coming from inlet1. I tried a lot in fluent, But I am not able to find a solution. Can any one help me to solve the problem. with regards, Dhayananth |
July 6, 2016, 13:06 |
#2 | |
Bhargav Bharathan
Rep Power: 11 |
If you have already run the simulation, then did you try getting your flow rate values from: Results -> Reports ->Surface Integral -> Choose velocity and your outlets From the known pipe diameter, material density and velocity you should be able to get you flow rate. -BB |
DPM mass flow rate | sajeesh | FLUENT | 8 | May 26, 2020 10:48 |
Discrete Phase Model, outlet mass flow rate does not fit | edu_aero | FLUENT | 29 | February 3, 2020 09:38 |
Target Mass Flow Rate | Nitin | FLUENT | 9 | June 17, 2017 11:30 |
Density of air for calculating the mass flow rate from Darcy's law | Hermano | Main CFD Forum | 0 | August 22, 2011 12:17 |
Calculating mass flow rate | cfd novice | FLUENT | 1 | April 3, 2008 19:31 |
