July 3, 2016, 18:06 |
simulating a propeller in fluent
mohammad ali
Rep Power: 11 |
hello everybody
I want to simulate a propeller is rotating in water in two situation in fluent. First, noncavitating Second, cavitating propeller. I'm new to such these problems and I want to know that: 1.What is better for this problem? rotating refference frame or sliding mesh? 2. Is cavitation for rotating propellers steady or unsteady? Imean how should i model the cavitation in a steady or transient manner? 3. After simulation how could i calculate the thrust and thrust cefficient of the propeller? 4. What is the AREA in refference values? because of thrust and other coefficients. I SIMULATE A PROPELLER DTMB4119 IN A STEADY MANNER WITH ROTATING REFFERECE FRAME BUT I GET FOR EXAMPLE A Cp DIAGRAM LOOKLIKES EXPERIMENTAL DATA BUT the numbers are bigger or i get the thrust coefficient 0.2 instead of 0.15. I will be grateful if anyone helps me... |
Simulating Electro-chemical reaction in Ansys Fluent | rsdsaurav | FLUENT | 1 | June 28, 2022 00:48 |
Simulating liquid metal in Fluent | Shamoon Jamshed | FLUENT | 10 | April 30, 2016 09:01 |
Propeller flow simulation in Ansys Fluent | a1ananth | FLUENT | 2 | December 4, 2014 16:30 |
Fluent capabilities in simulating turbomachies | CosmicRay | FLUENT | 0 | May 25, 2011 14:47 |
Simulating a Göttingen type wind tunnel in FLUENT | Chris | FLUENT | 3 | December 4, 2006 18:33 |
