Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
UDF for Drag law in DPM
Old   June 28, 2016, 17:57
Question UDF for Drag law in DPM
Leo
mail.leonardo is on a distinguished road
Hello everyone,
I am about start working on writing an UDF to modify the drag law in the DPM framework. In particular I should use the Syamlal O'Brian (parametric with Umf and Epsilon on fluidization onset from the experiment) drag law as I did for the TFM in order to compare the 2 different methods afterwards. I know that there is an old tutorial for the TFM multiphase application (made when ansysis still did not have this feature already implemented inside) but now I am struggling to figure how to apply the same procedure into the DPM scheme. Does anyone have any idea at this regard?
Thanks a lot for your attention and support,
Leonardo
mail.leonardo is offline   Reply With Quote
Old   July 18, 2016, 04:41
Fangfang Sun
ffsun is on a distinguished road
I am also trying to use dpm drag udf,but i cannot get good results. Do you figure it out? could you share something with me?
ffsun is offline   Reply With Quote
dpm, drag force, udf
UDF for DPM Law Switch Leepox Fluent UDF and Scheme Programming 0 August 26, 2013 06:36
Convert VOF droplet to DPM particle via UDF TedBrogan Fluent UDF and Scheme Programming 1 May 1, 2012 12:01
DPM: using UDF for creating and deleting Particles Markus Alzon FLUENT 0 July 4, 2007 02:18
DPM - UDF for fluctuating bubble size Jaroslav Kotara FLUENT 1 April 19, 2006 10:02
UDF DPM injection M.A. Rakib FLUENT 0 June 13, 2000 09:28
