June 17, 2016, 19:18 |
Evaporation of water droplet
Rep Power: 10 |
Hi. I am working on a simulation of evaporation in a capillary tube.
I am simulating evaporation of a water droplet sitting at the end of a capillary tube inside a solid body subjected to heat flux. the capillary tube is filled with water. I am using two phase VOF model, Lee model for phase change and I have used UDF codes for source terms and latent heat. It seems that my model does not capture the phase change properly. The liquid-vapor interface changes over time but it seems that water is just pouring down to the sides and not evaporating. I have defined the liquid-vapor interface as a hemisphere. In this stage, I want to merge the two phases (liquid and vapor) and use patch function for defining the interface to try another approach, However, I am not familiar with this process. I will be thankful If you can tell me how I should proceed to do this or what parts of the FLUENT guides might be helpful to solve my problem. |
October 1, 2018, 05:17 |
Water droplets evaporation rate in water spray system
Rep Power: 8 |
Dears,
I am working on spray cooling system via fluent. I want to check water evaporation rate in my results. I want to know that what percent of water droplets are evaporated but I dont know how to check. Would you please inform me? |
January 26, 2024, 22:55 |
#3 | |
Bidax
Rep Power: 2 |
have you been solve the problem? i have same question |
Water Surface Evaporation | sunggun1212 | FLUENT | 3 | January 11, 2020 05:12 |
discrete model problem (water droplet evaporation) | rabaeto1984 | FLUENT | 4 | October 1, 2018 05:16 |
Evaporation of thin water film | Stephen Waite | CFX | 6 | July 3, 2014 23:14 |
2D VOF Droplet evaporation model. Multi-component problem | nb92 | Fluent Multiphase | 0 | February 28, 2014 11:36 |
Water droplet motion and evaporation | Julie Polyakh | Siemens | 0 | November 16, 2002 15:16 |
