Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Need help with fluidized bed simulation
Old   June 8, 2016, 05:59
Default Need help with fluidized bed simulation
Phanakris Chuchaisri
sern is on a distinguished road
Hello everyone, I'm a chemical engineering master degree student and I'm very new to CFD. I need to use CFD to simulate the fluidized bed for further use in separation process. I've studied and tried fluidized bed workshop from Fluent. Then I'm trying to draw my own mesh and do it myself.
I draw the very simple geometry (just a 3D column with air inlet at the bottom) and generate mesh setting solver preference as Fluent. Then I import it into Fluent and try to do the same as the workshop, calculate it using Euler-Granular model and patch a volume fraction of particles at the bottom of column.
But I've got a problem, the simulation shows the particles flow with air at first as picture attached, some of them just flow out of column with air and then some of them fall down and start acting like fluidzed bed. How can I fix this?
Thank you in advance.
sern is offline   Reply With Quote
euler granular model, fluent, fluidization bed
Simulation of fluidized bed dar-2 Fluent Multiphase 7 May 12, 2016 11:23
Need guidance and tips about a fluidized bed reactor gasifier simulation cmigueis OpenFOAM 2 April 22, 2015 09:54
mass flow inlet condition is not properly specified in circulating fluidized bed abinashlipun FLUENT 0 April 19, 2013 03:28
Simulation of a fluidized bed sydney_tekam Main CFD Forum 0 April 12, 2010 09:24
Questions about gas-solid fluidized bed simulation Sinferm FLUENT 1 January 31, 2007 15:54
