Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Numerical Diffusion of the Interface of a Patched Bubble
Old   May 28, 2016, 08:18
Default Numerical Diffusion of the Interface of a Patched Bubble
Fengleng Yao
Rotkohl is on a distinguished road
Hi everyone,
I get a problem of the numerical diffusion of the phase boundary when simulating a rising bubble in quiescent liquid.
The case is that a single bubble of air (diameter=1mm) rises in a cubic container (8mm*8mm*6mm) fulfilled with water, which boundary condition of its bottom and side is set as Wall and the top the pressure-outlet. The case was simulated both in 2D and 3D and all the settings are the same. I patch the bubble in a circle or spherical region with the initial position (0.004m,0.004m,0.0025m). However, a serious numerical diffusion of the phase boundary occurs only in the 3D case (as shown in attachment Figure 1) when bubble have already rised for a while. As seen the interface contains 5 more cells, which is unreanable.
Can anyone help me to solve the problem?
Thank you!
P.S. The improtant settings of the case are presented in the attachments.
Rotkohl is offline   Reply With Quote
vof interface diffusion
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 10:49
pressure difference on bubble interface Ron FLUENT 0 June 24, 2004 07:09
Numerical diffusion error Z.Zeng Main CFD Forum 8 October 22, 1999 10:06
