Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Why the water is flowing along the wall by VOF model?
Old   February 15, 2018, 07:59
Michal
michal.s is on a distinguished road
Thank you, I will try in immediately.
Do you recommend some specific time step or solver options for VOF?
I was running one-phase simulations for this case with PV Coupling as Coupled, PRESTO! pressure discretization and pseudo transient.
michal.s is offline   Reply With Quote
Old   February 15, 2018, 10:34
usama
usamaperwez is on a distinguished road
Use variable time step (it is recommended for VOF), it will automatically try to adjust according to courant number.
PV Coupling as PISO
Gradient as Least Square Cell
Pressure as PRESTO
Momentum as Third order muscl
Volume Fraction as Geo-Reconstruct
Transient as First order implicit
In VOF model setting, activate Coupled level set also.
usamaperwez is offline   Reply With Quote
Old   February 15, 2018, 10:56
Michal
Thank you!
It looks like calculations goes a little bit better, however my time step is changing aroind 1e-07 / 1e-06.
I'll say what's the result after some calculations.
Looks like my mesh is too fine
Old   February 15, 2018, 10:58
usama
Mesh aspect ratio should be 1.
It will take time since one of my simulation run at 1e-08 and it took 7 days to complete.
Old   February 16, 2018, 15:21
Michal
I tried all what you have suggested.
Worked a little bit better.
https://www.youtube.com/watch?v=DJwJ...ature=youtu.be
There is a short video with the results.
Still it doesn't behave properly.
Looks like the water stream is "laminar", like it was a vapour.
I also tried to do fast calculation using LES. With LES the flow was natural (as I wish to be).
Maybe I should manipulate with k-w settings?
Old   February 17, 2018, 02:08
usama
another thing is that there is a collision. So you may need to activate collision model also. Just see the following collision tutorial on CFX using free surface model (same as VOF).
https://www.youtube.com/watch?v=KdFlwgLEnlo&t=16s
You want to generate splashing basically, i think so?
What about the wall contact angle? it is also very important in this situation.
Old   February 17, 2018, 07:02
Michal
I tried to modify the contact angle before, but didn't bring any changes (obviously that I have achieved before wasn't correct).
Thank you for the tutorial, that is moreless what I expect.
We are going to run an experiment, I am uploading a picture of what we had n the lab.
https://ibb.co/h4X0Ln
About collision in fluent - isn't in inside DPM?
I have to say usamaperwez I really appriciate all you suggestions and help! Without it I would be my nightmare
Old   February 27, 2018, 12:43
usama
I rechecked again, there is no need of collision model.
Did your problem got solved?
Old   February 27, 2018, 12:54
usama
which scheme are you using of VOF?
If it is explicit then try moving towards implicit !
Old   February 28, 2018, 03:57
Michal
Still doesn't work as I wanted to.
Using different turbulence models and settings the flow behaviour was changing. The realistic solution was with LES, however I would like to get it with k-w, k-E or RSM.
I also tried with steady state - sometimes it worked - stream shape became OK
vof two-phase
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 09:16
Displying interface of liquid water using VoF model pchoopanya FLUENT 2 March 15, 2013 17:42
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
