Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Mass flow rate of each phase at outlet
Old   April 1, 2016, 00:36
Default Mass flow rate of each phase at outlet
Ahmed Saieed is on a distinguished road
Hello and good day,
I am working on a piping network in which I have one inlet and two outlets. I am introducing air and water in to this system and my aim is to find the mass flow rate of each phase at both the outlets. As a beginner I am not about to figure out how I can do this. Currently my boundary condition at outlet is pressure outlet. can anyone help me with this.
Thank you
Ahmed Saieed is offline   Reply With Quote
Old   April 4, 2016, 18:28
`e`
`e` is on a distinguished road
Have a read of this thread on a UDF for measuring the mass flow rate at the outlet. As your problem is multiphase, then have a read of the "Special Considerations for Multiphase UDFs" in the UDF manual (use the phase domain index to distinguish between phases).
`e` is offline   Reply With Quote
Old   April 4, 2016, 23:22
thnx.... I am currently using monitors to generate graphs for mass flow rates at outlet and inlet.. the problem is that according to these graphs the mass flow rate at outlet is greater then inlet.... does it means the graphs generated by monitors arent accurate ?
Old   April 5, 2016, 00:03
`e`
Is your simulation converged and is it steady or unsteady? For a converged steady state case, you should expect the inlet mass flow rates to equal the outlet mass flow rates.
Old   April 5, 2016, 00:18
My flow regime at this moment is stratified. so its a steady state case.
No it havent converged. My flow rates of both the phases at outlet are kinda werid right from the start.. and thats wht worries me coz their sum should be equal to the inlet mass flow. this is wht conservation of mass states.
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 11:40
DPM total mass flow rate yow FLUENT 0 July 17, 2015 13:01
How to change from mass flow to volume flow rate stanley FLUENT 1 February 2, 2007 07:44
Mass flow rate in outlet Saturn FLUENT 1 October 11, 2004 10:39
Constant mass flow rate / choking outlet bounardy condition Min Zhu Main CFD Forum 1 September 29, 1998 16:33
