March 7, 2016, 23:17 |
Pressure increase across a interphase
Carles
Rep Power: 10 |
Dear all,
I am simulating the flux of air in a system in which a droplet is suspended in a glass (as attached), but there are only defined the droplet phase (liquid) and air (air). So I use VOF with laminar only. The problem is that when I compute the solution only with a velocity defined, 0 gauge, and 1 of Volume fraction of species 2 in inlet (air enters the system) and I patch that air is air (1) and droplet is liquid (1) the results that I obtain are strange. To begin with the solution is very slow, I have tried constant step and not constant and the solution always is behaving like increasing and decreasing constantly. When I see the results for a low time step I see that in less than 0.01 seconds, the water goes out of the droplet (not logical) and the pressure inside the droplet increase a lot So what is the problem? the only thing that I find strange in the configuration is that the interface water-air (droplet surface) is duplicated Thanks for all |
November 6, 2017, 13:56 |
Abd Essamade Saufi
Rep Power: 9 |
Hi Carles,
which software are you working with (Fluent/OpenFOAM)? This may be a problem of spurious currents. What is the diameter of your droplet? |
Pressure loss Velocity coupling | CFXMUFFIN | CFX | 1 | February 6, 2016 05:43 |
Discharge of Pressure Vessel into Pipe with Regulator | gajowni2 | System Analysis | 0 | October 31, 2015 19:57 |
InterPhaseChangeFoam ERROR | shipman | OpenFOAM Running, Solving & CFD | 37 | March 23, 2014 13:43 |
Setting up the pressure variation due to tornado in a duct(UDF)+animation | guillaume1990 | FLUENT | 0 | March 3, 2014 12:59 |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 18:19 |
