Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Multiphase model issue linked with hot air injeted into the water
Old   March 7, 2016, 12:07
Default Multiphase model issue linked with hot air injeted into the water
Id7
ilikescience is on a distinguished road
Hello Forum friends, I was expected to simulate the evaporator in which the hot air was injeted into the water via a tube and form bubbles before those bubbles exchange heat and mass with the surrounding water. For a test model I use 2d model.
I use mixture model, alongside with species model in which I create water(vapor)+ air mixture. I set the interaction between the phase of water(vapor)+air and the water(liquid) and I was hoping to see the bubbles in the contours via the difference of volume fractions, but I failed.
So my questions are:
1. Have I been in the right path of simulating the interaction between air, water vapor and water liquid? If so, I would appreciate if someone can tell me how to deal with the outlet BC
2. How should I set up my Fluent conditions to get to my goal of observing the evaporating rate?
3. Should I use VOF instead?
I have been struggling with this topic and I would appreciate any answers you would give.
Best wishes and many thx
eric
ilikescience is offline   Reply With Quote
air-water interface, mixture model, multiphase flow
No liquid water exist in my Fuel Cell simulation fatchang FLUENT 19 October 15, 2018 15:27
air into box filled with water, outflow for water at bottom dieterdanger Fluent Multiphase 0 July 16, 2015 17:11
ansys cfx solver exit with return code 1!!!!! mhabibnia CFX 7 August 19, 2013 04:53
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
Kinetic air props model - conductivity HALF? Chris Bailey FLUENT 1 March 7, 2006 11:38
