Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
3 phase flow through pipe
Old   March 3, 2016, 02:03
Default 3 phase flow through pipe
Thasneem Moosa
thasneem is on a distinguished road
Dear sir,
While setting up a model in fluent for three phase flow what should be the operating conditions given regarding density? Should that necessarily be of a lighter fluid?
Is it right to interrupt a solution before it could complete the iterations to check the volume fraction through out the model and yet obtain a correct solution?
Last edited by thasneem; March 3, 2016 at 02:08. Reason: additional clarification required
thasneem is offline   Reply With Quote
Old   March 3, 2016, 11:03
Jim
CFDYourself is on a distinguished road
Originally Posted by thasneem View Post
Dear sir,
the density you're setting is likely to be whatever the continuous phase is. so if you have a droplet-laden gas say, it would be the gas density. if you have a liquid + bubbles or + solids, it would be the liquid. but this depends on the model you are using. you should set the density of all of the components of the medium really.
in answer to your 2nd question it depends whether or not your solution is converged. is all of the residuals are low (<1e-3) then the solution is converged. you only keep the simulation running if its transient, if you want better convergence. if your solution if unconverged, then you should not try to extract data from it because the answer can be far away from the correct answer, and can be misleading.
the actual process of interrupting by ctrl+c shouldn't affect the answer.
CFDYourself is offline   Reply With Quote
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 09:38
Setting boundary conditions for simple pipe flow with flow direction changing in time Sipher FLUENT 1 May 4, 2015 21:05
multi phase flow with chemical reactions in one phase Habibfateh OpenFOAM Programming & Development 0 February 10, 2014 08:33
two-phase flow with a single phase simulation caunima Fluent Multiphase 0 October 28, 2013 03:42
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
