Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
y+ for Eulerian granular model, pipe flow
Old   February 27, 2016, 08:18
Default y+ for Eulerian granular model, pipe flow
Timur
Timur is on a distinguished road
Dear all,
I have a little bit tricky question and will be happy if any of you knows the solution.
I have a 2D pipe in which I simulate particle plug propagation using Eulerian granular model. Basically, the particles are transported at almost packed conditions (volume fraction is always around 0.6). So, due to this fact, the viscosity at the wall in the region with particles is very high and the velocity is small.
I use k-e model for turbulence with EWT. The pipe is 3.2 cm. When I mesh the pipe, I mesh it like for a single phase flow for y+=30. I am doing so because I read that at this y+ the k-e model gives better solution. But due to the fact that the viscosity at the wall in the region with particles is very high and the velocity is small, y+ for the particle is around 0.5-1. If I calculate the first layer thickness for particle velocity and viscosity, it has a value higher than the diameter which, of course, does not make any sense.
So, my question is - do I need to take into account the y+ for particles? Can k-e model work well when I have this y+ for the particle region? or I can simply consider that y+ is OK for the continuum phase and carry on with my simulation?
I would really appreciate any help!
Kind regards,
Timur
Timur is offline   Reply With Quote
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 09:38
Help: apply B.C. in my granular flow model ? Derek Jing FLUENT 1 January 8, 2020 22:38
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
about granular flow model daninwin FLUENT 0 January 19, 2001 04:47
