Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
VOF : reproduce Variable Time Stepping Algorithm
Old   February 22, 2016, 11:59
Default VOF : reproduce Variable Time Stepping Algorithm
Lars
sral is on a distinguished road
I am simulating a two-phase flow (water and air) and in order to understand the variable time stepping algorithm better, I try to calculate the next physical time step FLUENT will use following the equation given in the manual (Link)
So I found the tui command
/report/fluxes/mass-flow
which will give me the mass-flows for my four cell zones (i.e. zone1, zone2, zone3, zone4) in my domain.
And
/report/volume-integrals/mass
will give me the mass for each of my two phases in the four cell zones. (I didn't find any command to report the volume fluxes, so I think using the mass fluxes divided by the mass will work)
So I set up an excel sheet to calculate myself with the values given by the aforementioned tui commands:
click for larger image
For this arbitraty state in the simulation process I get a physical step size of 0.006746321 seconds for the next iteration, but when I start the iteration in FLUENT, it defines 0.0013777 seconds.
I defined high values for the maximum time step size and the maximum step change factor and low values for the minimum time step size and minimum step change factor respectively. So none of these boundaries will take effect.
Can you please point out, where I am missing something?
When the manual says
where the ratio is calculated for each cell.
does it mean for each cell zone or for each of the finite volume elements?
Thank you!
sral is offline   Reply With Quote
Old   February 23, 2016, 08:12
hwet is on a distinguished road
do you specify a courant number as well? Maybe it is just trying to keep to the maximum courant number value you have specified by keeping the time step small
hwet is offline   Reply With Quote
Old   February 23, 2016, 08:52
Lars
Thank you for your reply.
In Fluent as well as in my Excel calculation I specify a courant number (CFLglobal) of 2.
Yes, the variable time stepping method of Fluent tries to stay at CFLglobal = 2. In order to do so, Fluent uses the equation .
But when I calculate myself, I get a different value. So the values for "outgoing fluxes" and "volume" I extract from Fluent seem to be different from the values, which Fluent uses to calculate .
Based on the statement
Originally Posted by Fluent Documentation
The variable time step is based on the maximum Courant number near the VOF interface. To calculate that Courant number, ANSYS Fluent uses a flux-based definition where, in the region near the fluid interface, ANSYS Fluent divides the volume of each cell by the sum of the outgoing fluxes.
it seems, that Fluent uses the "outgoing fluxes" and "volume" of selected finite volume elements (called "cells" in this case), maybe something like VOFwater = 0.4 ... 0.6, near the water-air-interface and not the whole cell zones.
So when I use the cell zone values, which are averages of all containing finite volume elements, the fluxes are not as critical and therefore leading to a bigger in my manual calculation.
Is there a way in Fluent to report the element based volume fluxes? Preferably of a preselected set of elements (e.g. VOF = 0.4 ... 0.6) ?
Old   February 24, 2016, 18:37
in the vof window there is a courant number option as well which is for the phase and different from the global courant number, check that out as well.
cfl, courant, step size, vof
courant number in vof reza_gharib1369 FLUENT 49 February 26, 2020 17:55
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 11:08
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
variable time stepping text commands moe FLUENT 0 September 2, 2009 12:19
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
