Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
DPM Single Particle
Old   February 18, 2016, 08:09
Post DPM Single Particle
Gregory Hannam
greg_2666 is on a distinguished road
I need to look at a single particle in a cylinder that is rotating - it's the inspection process for contaminated syringes.
I can't seem to find any guides on particle modelling that don't use an inlet.
I've tried doing it myself but nothing seems to be visible.
Has anyone done something similar?
Thanks a lot,
Greg
greg_2666 is offline   Reply With Quote
Old   February 19, 2016, 08:41
Jim
CFDYourself is on a distinguished road
Hi Greg,
You need to provide a injection point for your particle. This'll be a point location where your particle is introduced. This shouldn't require a fluid "inlet" in the domain.
CFDYourself is offline   Reply With Quote
Old   February 22, 2016, 11:10
Cees Haringa
CeesH is on a distinguished road
Also note that you need to run your simulation in transient mode, as their are no complete trajectories from an in to an outlet. And, as far as I know at least, you won't easily 'see' the particle track, FLUENT itself only visualizes the instantaneous position of the particle. To see the history, you can export an xml file with the trajectories (visualizable with CFD post), or export the trajectories otherwise, using an UDF or so.
CeesH is offline   Reply With Quote
dpm, fluent, particle
DPM particle time step amos FLUENT 1 January 4, 2020 09:46
UDF for particle interception with pt_termination fortran routine abcdefgh CFX 6 October 6, 2019 14:30
Dpm model, setting particle number wagnerqb FLUENT 7 March 23, 2013 22:06
In steady DPM model, how to get a particle residence time in a specific cell? DanK FLUENT 1 August 25, 2012 01:33
Burning Particle (DPM) sega FLUENT 2 July 31, 2010 05:08
