Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Thermohaline Current
Old   February 11, 2016, 12:18
Default Thermohaline Current
mehdi benkabouche
mehdi199 is on a distinguished road
I want to reproduce the thermohaline circulation on fluent , i need to use two fluid (hot & cold water) , i know i must use the multiphase but i don't know how to set it.the result must be like this :
https://interstices.info/upload/docs...bouteilles.mp4
Thank you
mehdi199 is offline   Reply With Quote
Old   February 12, 2016, 15:06
Hesam
Hesam_Ami is on a distinguished road
Hello Mehdi,
Because the boundary between the two fluids is clear, you should use vof model.
( mixture >> vof)
Hesam_Ami is offline   Reply With Quote
Old   February 13, 2016, 17:24
silent2608 is on a distinguished road
use vof model, explicit
how to get water into your model
- initialize with 0 water volume fraction (only air)
- adapt region -> mark regions where you need water initially
- in solution initialization window go patch -> use the region, select your water phase and patch the zones with vol.fraction = 1 for water
- with energy equation enabled I think you can also use the same region to patch the cells with temperature afterwards
google vof best practices fluent or something similar to get some pointers on decent settings to start with (I'd use mapped quad mesh, presto, compressive interface reconstruction, explicit vof w/ variable time stepping (courant <= 1)
edit: works like I thought, patch fluid, then patch temperature in those cells afterwards
silent2608 is offline   Reply With Quote
Old   February 14, 2016, 08:44
mehdi benkabouche
Thank you , i'll try it.
Old   February 16, 2016, 14:18
mehdi benkabouche
I don't why i can't patch temperature ?
Old   February 16, 2016, 15:48
enable energy equation
patch water
patch window select mixture, select temperature, input temperature in kelvin, select region to patch -> patch
now you have patched water and afterwards patched that region with the temperature you need
VOF solves single set of equations for the whole domain, hence you can't select a phase and patch temperature for a phase
I guess if you will VOF model is pseudo-multiphase, it solves equations based on local density, but it's not actually aware there are discrete phases (which is why reconstruction step builds phase interface from local density)
Old   February 17, 2016, 07:54
mehdi benkabouche
It works , thank you
Current density visualisation (PEM fuel cell add-on module) pchoopanya FLUENT 10 August 21, 2023 15:33
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
How to set current Jendge FLOW-3D 3 November 25, 2014 19:48
What is the difference between current time step and current time djing FLUENT 4 May 1, 2012 17:18
dilute gravity current at very flow base doronzo FLUENT 0 October 5, 2011 16:38
