Problem with slug(or taylor) formation in a microchannel |
Alan Zago de Souza
Rep Power: 11 ![]() |
Hello guys,
I'm working with two phase flow (gas-liq). I'm using an experimental data for validate my model. My model can predict the regime in some especifics meshs, when I started to refine the mesh the slug don't form. I don't know yet why. In attachment there's a formation of a slug (rough mesh) and other image (fine mesh) where the formation don't occurs. Someone already had this problem? |
Rep Power: 10 ![]() |
Hi, please post images of the mesh and dimensions of mesh (also what's the vertical dimension of the pipe in mm?) + surface tension and wall adhesion related settings. If both have been done with the same settings and only mesh size is different that would be very interesting.
Other than that generally speaking VOF multiphase results will never be mesh independent (meaning unlimited fine mesh does not mean converging results). Initially you will get better results with a finer mesh, but at some point your results will diverge usually. |
fluent, mesh, slug, two-phase flow |
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 07:27 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
PROBLEM REGARDING MICROCHANNEL HEAT SINK | SHAKUNTALA OJHA | FLUENT | 3 | May 27, 2008 12:14 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
