February 3, 2016, 13:46 |
VOF convergence in open channel flow
Rep Power: 12 |
Hello.
I am simulating an open channel flow, steady simulation. Why all the variable reach the convergence (the residuals of K, epsilon, velocity, etc. reach 10^(-4)), whereas the continuity equation residual is constant at 10^(-1)? I checked the results and nothing seems to change during the iterations. Thank you |
March 16, 2017, 11:46 |
residual increase after 500 iteration
kemin ali
Rep Power: 11 |
Have you solved your problem. For my case the residual increased a lot after 500 iteration. Any tips to fix the problem? |
convergence, open channel flow, residuals, steady state, vof |
Flow Depth in VOF open channel flow | akjha | Main CFD Forum | 3 | November 5, 2015 03:07 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
open channel flow model VOF in fluent | yasar248 | FLUENT | 0 | April 13, 2015 03:26 |
Yacht in Open Channel Flow | andreimour | FLUENT | 1 | October 14, 2010 23:54 |
open channel flow boundary conditions | yan | FLUENT | 0 | July 4, 2005 23:36 |
