Dynamic mesh setup, VOF 2 Phase, moving zones, possible? (diagram / picture) |
Rep Power: 10 ![]() |
I'm new to dynamic meshing, I need to lower the computational cost of my problem. My idea was to use dynamic meshing to accomplish this, however since I have no experience with it I need basic guidance on whether or not this is even possible. ![]() Water / oil is simulated in a capillary which is otherwise filled with air. I want to define various coarse / fine zones within the mesh. Part of it will be filled with the fluid. At first I will do a 1s simulation without gravity until the curvature is stable, then gravity will be activated and the mesh sorrounding the fluid has to move with the fluid. I need to do this to get a high resolution fluid/gas interface, which will be necessary for follow up simulations (marangoni flow, heat transfer within that region etc.) I understand interfaces between coarse and fine meshes need to be modeled because they are matching surfaces with different mesh topology. How do I manage to apply movement v(g)? Is the 6DOF solver appropriate? Any help regarding setup is very much appreciated, especially because the movement v(g) can't be defined as a value, since it will change throughout the simulation. |
So far I've tried sliding mesh, two adjacent zones have contact via interface.
Dynamic mesh is activated (layering etc. all deactivated) and one of the zones has been set to a fixed translational velocity in cell zone conditions. Interface options is set to periodic boundary condition. I don't get any movement whatsoever even though it is specified and I get no errors. |
Mohammad Mehdi Basirat Nejad
Rep Power: 3 ![]() |
Hi, I have approximately the same problem and I can't do anything about these two complexities in one problem. my problem is cooling of a moving disc by an impinging oil jet.
Do you have some advise for me? |
Is my Dynamic mesh setup correct? | cfd seeker | FLUENT | 16 | October 30, 2020 06:16 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling | spaceprop | FLUENT | 5 | September 2, 2014 09:43 |
Question on moving mesh, mesh velocity is really small! | ripperjack | Main CFD Forum | 2 | April 28, 2014 13:37 |
