Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Best model to investigate fouling
Old   January 20, 2016, 08:04
Default Best model to investigate fouling
Hassan Mroue
mroue is on a distinguished road
Send a message via Skype™ to mroue
Dear all,
- Can anyone tell me what is the best model to investigate fouling in heat exchangers. I am just running a simple 2D rectangular geometry to understand how different model works then later apply it to a whole heat exchanger system. I will be introducing ash solid particle inside the fluid flow for this investigation.
- What is the difference between DDPM (Eulerian multiphase model) & DEM collision VS DPM DEM collision. I wonder if using any of the mentioned models would visualise and calculate the fouling layer thickness for different inlet flow rates.
Many thanks,
Hassan
mroue is offline   Reply With Quote
Old   August 28, 2018, 09:02
imane
zahrae is on a distinguished road
Hello!
I am working on modeling of fouling in heat exchangers, I use DPM model, but I face a problem, when I activate the thermophoretic model to take in consideration the effect of thermophoresis forces on particle trajectories, fluent generate an error "Error: received a fatal signal (Segmentation fault).
Error Object: #f", I am searching for the sources of this problem and I found that it is in relation with UDF but I am not using any UDF in my simulation!!
Could you please help me and telling me how you modeled the fouling in your simulation?
best regards.
zahrae is offline   Reply With Quote
eddy dissipation model: combustion doesn't occur roukaia FLUENT 2 November 18, 2020 11:23
Turbulence model choice dave13 CFX 3 December 22, 2015 08:12
problem with solving lagrange reaction cloud Polli OpenFOAM Running, Solving & CFD 0 April 30, 2014 08:53
manualInjection model in sprayFoam Mentalo OpenFOAM Running, Solving & CFD 1 April 2, 2014 10:29
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
