January 10, 2016, 02:00 |
Parasitic currents in VOF
joseph
Rep Power: 11 |
hi friends,
i am trying to simulate two phase gas-liquid flow in microchannels using Explicit VOF in ANSYS FLUENT. On the gas-liquid interface some un-physical velocities(parasitic currents) are developing, especially where the interface meets the channel wall. These velocities are large enough to alter the expected flow nature. How can I eliminate these velocities? my settings are, 1.CSF model for- surface tension modelling(interestingly the parasitic velocity direction is reversing when CSS model is used) 2.numerical schemes are, PISO,PRESTO, second order upwind and Geo-reconstruct plz help........ |
February 4, 2016, 11:52 |
Rep Power: 11 |
unfortunately inherent to CSF model, read the theory behind it for clarity
http://www.ann.jussieu.fr/frey/paper...%20tension.pdf I'm not quite sure myself how to address this issue or how to lower its effect. If you manage to find answers please report. are you using explicit scheme? I would assume explicit vof with courant ~< 0.7 might help |
February 10, 2016, 16:23 |
Alan Zago de Souza
Rep Power: 12 |
I think you can try to used the compressive scheme. Using with your setup and a good mesh the parasitic currents will be reduzed |
parasitic currents | rcastilla | OpenFOAM Programming & Development | 135 | November 29, 2017 11:53 |
parasitic currents in a two phase flow case | AnasCFD | OpenFOAM Running, Solving & CFD | 0 | July 11, 2015 18:42 |
interFoam channel hull parasitic currents? | Mock | OpenFOAM Running, Solving & CFD | 4 | August 14, 2014 19:26 |
interFoam grid refinement results and parasitic currents | giack | OpenFOAM Running, Solving & CFD | 0 | June 29, 2013 13:45 |
parasitic currents | Pei-Ying Hsieh | Main CFD Forum | 0 | January 13, 2009 20:58 |
