January 4, 2016, 06:06 |
Phase Change Modeling
Amar
Rep Power: 10 |
Hello
i want to simulate the phase change of freon using ANSYS FLUENT through straight capillary tube the Dimensions of capillary tube : inner diameter = 1.5 mm length = 1500 mm the objective of this simulation is to plot pressure, velocity and quality distribution along capillary tube thanks |
January 4, 2016, 22:26 |
Phase Change Modeling using Fluent
Amar
Rep Power: 10 |
hi
i want to simulate the phase change of freon through capillary tube any advice helps me thank you |
January 5, 2016, 11:10 |
Phase Change simulation
Amar
Rep Power: 10 |
hi i want to simulate the phase change of freon through capillary tube
1-i wish to use gerber cavitation model in ansys fluent to study phase change 2- how can i define the thermophysical properties as polynomial function of temperature how can i solve the problem of phase change any advice helps me |
January 7, 2016, 09:30 |
Amar
Rep Power: 10 |
hi all
i am want to simulate phase change from liquid to vapor the liquid is set as a contineous fluid and vapor as a dispersed fluid i am using thermal phase change there is no results to me i appreciate any help in this field thanks |
January 7, 2016, 09:32 |
Amar
Rep Power: 10 |
i have the same problem
can you help me if you solve it |
January 7, 2016, 09:56 |
Ram Kumar Pal
Rep Power: 11 |
Dear friend, please explain your problem briefly what you want to simulate.
January 7, 2016, 14:50 |
Amar
Rep Power: 10 |
thank you dear
i have small diameter long tube the working fluid is freon now let me explain the phenomenon : the freon enters to the tube as a liquid freon and after some distance ,flashing phenomenon will takes place and vapor will form . in this way i have two phase fluid flow that is mean there is phase change takes place from liquid phase to mixture(liquid + vapor)phase . i want to simulate this phase change problem |
January 11, 2016, 15:53 |
zduno
Rep Power: 13 |
try the tutorials
June 24, 2019, 06:47 |
#9 | |
Vignesh Lakshmanan
Rep Power: 10 |
Have you solved the problem?? I face a similar problem |
Refrigerant R134a Phase Change | Mahesh Bondhu | FLUENT | 4 | May 4, 2013 09:13 |
Solid/liquid phase change using large viscosity | gregor.vidmar153 | OpenFOAM Running, Solving & CFD | 3 | June 10, 2010 07:31 |
How to model the solid-fluid phase change in CFX | ohrmond | CFX | 2 | May 26, 2006 07:27 |
thermal phase change question | CFDflying | CFX | 1 | February 18, 2004 05:10 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
