Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
natural convection
Old   December 31, 2015, 06:50
Default natural convection
sa har
sa har is on a distinguished road
hello,i try to simulate a solar air heater in ansys fluent.i have a channel that air entered of bottom and go out of up by natural convection.
boundary condition is:inlet(pressure inlet),outlet(pressure outlet)[both inlet and outlet pressure are 0],and boussinesq model for natural convection.
when i run,i have reverse flow that it disappeared after 1000 iterations. when run finished my pressure increases and counter of pressure is wrong,can you help me?
is operating pressure important?what means of operating pressure?
sa har is offline   Reply With Quote
Old   January 1, 2016, 08:36
amir
ghorbani1992 is on a distinguished road
Send a message via Skype™ to ghorbani1992
I think change your pressure solution method to PRESTO!
what is your turbulence model?
ghorbani1992 is offline   Reply With Quote
Old   January 1, 2016, 10:09
sa har
hi amir,
i used standard-k-epsilon for turbulance model.and i used standard method for solve pressure.
when air move up,velocity should be increase and pressure decrease?is right?
thanks alot
Old   January 1, 2016, 12:44
Smile
amir
Originally Posted by sa har View Post
hi amir,
thanks alot
hi sahar
whenever change flow rate or cross section the velocity must be increase or decrease . but pressure must be decrease.
if in your problem , natural convection ( buoyancy force ) due to air flows , don't forget insert gravity.
I think that you have a correct simulation.
Old   January 1, 2016, 12:52
sa har
hi sahar
yes,i insert gravity and i use bussinesq model.but my pressure increase when air move up.i think its maybe wrong.yes?
Old   January 1, 2016, 13:34
amir
i thing that's wrong. change model to ideal gas ( for High temperature range recommend use boussinesq model).
If you can explain the problem in detail, may be i can describe it in more detail.
Old   January 2, 2016, 05:44
sa har
i have channel that inlet is down and outlet is up,and left of channel is glass and right of channel is absorber.geometry is 3D.and i insert source term in absorber because of solar irratiton.glass wall boundray is mixed of convection and radiation,and other wall is heat flux=0.inlet is pressure inlet and temp is 320K and outlet is pressure outlet.and i active radiation DO model or S2S model.i want velocity in outlet
now i want test ideal gas instead of boussinesq model.
thanks alot
UDF of natural convection in 3D cylinder a_Sarlak Fluent UDF and Scheme Programming 0 November 7, 2015 09:19
Thermophysical properties for natural convection Ciefdi OpenFOAM Running, Solving & CFD 0 November 7, 2013 12:44
Natural Convection - Problem in achieving converged solution howhs FLUENT 2 August 28, 2013 11:51
natural convection problem with radiation jorien CFX 0 October 14, 2011 10:26
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 05:58
