Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
UDS for gas-phase in cavitation models bug
Old   December 31, 2015, 01:38
Default UDS for gas-phase in cavitation models bug
shaham
shaham is on a distinguished road
Hi everyone,
I want to implement a new cavitation model using DEFINE_CAVITATION_RATE and I need to define a UDS for non-condensable gases mass fraction in the gas phase. I came up with a problem, which I don't know the reason for that. The problem is:
when I enable the cavitation model, and define a UDS for gas phase, and set the boundary condition of the UDS at inlet as a constant value, the UDS value comes to zero right after the inlet. I found out that this occurs when the gas_volume_fraction*gas_density is less than a certain value. The values I set are 0.0001 for vol. fraction and 1 for gas density. The inlet value for UDS doesn't affect the results. I used the UDF to set the *m_dot for cavitation to 0 to make sure there is no mass transfer. therefore, I can see the gas volume fraction spreading in the geometry, but not the UDS value.
So I wonder if anyone can tell me what the reason is, whether it is a bug or it is fixable? I hope I can find a solution, because using the mass transfer UDF is a pain!
P.S. If you want to test it yourself, define two phase, mixture phases, liq and gas for any geometry. for inlet, gas volume fraction set to 0.00001 and gas density 1, liq density 1000.
shaham is offline   Reply With Quote
bug, cavitation, uds
Cavitation models Ram Siemens 1 January 12, 2005 09:31
Compatibility LES and Discrete Phase models JADG FLUENT 0 January 22, 2004 21:03
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 16:39
Two phase flow models Atholl Main CFD Forum 2 May 7, 2002 04:49
