Multiphase flw of nanofluids - low Nu problem |
October 30, 2015, 02:31 |
Aarthy Meena
Rep Power: 10 |
Hello Everyone,
Am Aarthy, I am new to FLUENT. I am modelling 2-D flow and heat transfer of nanofluids around an unconfined square cylinder for my M.Tech project. Initially, I tried a single phase flow using effective property models for properties of nanofluids. Those simualtions are fine and gave comparable results with the literature. Now, I am trying to use multi-phase flow model. I am trying with mixture model in FLUENT. I tried with particle volume fraction as 0 (i.e., pure basefluid), and I got good values of Nu and drag coefficients which matched with literature. When I increased the particle volume fraction, the values of Nu and C_D decreased. But, it is well known that, when particle volume fraction is increased, C_D and Nu will increase. So I am stuck with this. Kindly, pls help me very urgent.... |
October 31, 2015, 12:03 |
#2 | |
Khalid Baker
Rep Power: 17 |
Hello did you study flow of nano-fluid over cylinder? you mean an external flow problem?
November 1, 2015, 00:59 |
#3 | |
Aarthy Meena
Rep Power: 10 |
My problem is that with an increase in particle volume fraction, I observe a decrease in mean Nu and C_D at all Reynolds number. This is contradicting with the basic behavior of nanofluids and literature. I am stuck with this and I am unable to proceed with my work. Kindly, Please help me solve this. |
mixture model, multiphase flow, wrong nu and c_d |
Problem accessing material properties in UDF for Multiphase Multispecies | pmtgt | Fluent Multiphase | 3 | January 17, 2021 07:11 |
Boundary Condition problem with multiphase flow | daroz | OpenFOAM Pre-Processing | 0 | August 13, 2013 11:09 |
Low pressure de Laval simulation convergence problem | heksel8i | FLUENT | 3 | July 22, 2013 10:28 |
SetFieldsDict file problem with 3D multiphase flow | jeff_87 | OpenFOAM Pre-Processing | 11 | May 3, 2013 06:20 |
multiphase mixing Problem with MRF model in MixSim | Srinivas | FLUENT | 0 | October 17, 2005 06:35 |
