Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
open channel inizialization with water surface parallel to the bed
Old   October 9, 2015, 17:22
Default open channel inizialization with water surface parallel to the bed
Ema40 is on a distinguished road
Dear all,
I would like to simulate an open channel flow, but I have a problem in the initialization.
As initial condition I would like to have a water profile parallel to the bed, thus I impose a free surface depth at the inlet and at the outlet.
I use the FLAT initialization for open channel flow, but the free surface which is generated is horizontal, and not parallel to the bed. I have tried to use both hybrid and standard initialization, starting both from the inlet and from the outlet, and also selecting "all zones".
Do you have advices?
Thank you
Ema40 is offline   Reply With Quote
initialization, inlet, open channel flow, water depth, water surface profile
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
free surface level set in in Open Channel Wave BC hamidcfd Fluent Multiphase 2 December 12, 2016 13:08
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
