September 23, 2015, 02:19 |
Density [(kg/m3)m2] in Fluent?
Rakibul Islam
Rep Power: 11 |
Hello
I am doing a simple two phase 2d simulation. Actually I am interested to check the density variation at outlet. So from surface monitor, I selected: Report Type- Integral and Variable - Density but I am confused about unit that I am getting on the plot. Please check the attached file. What does that unit mean? |
September 23, 2015, 03:14 |
Rep Power: 13 |
Try with sum or avg instead of integral
September 29, 2015, 07:52 |
Monitor
Rep Power: 12 |
Area-weighted average should be fine for this.
October 13, 2015, 11:57 |
Jim
Rep Power: 11 |
I second landerfwc - "area weighted average" arguably the best option.
When you select "integral" you're getting the INTEGRAL across the outlet's 'face'. This is why you get the units in (kg/m^3) * m^2. |
Current density visualisation (PEM fuel cell add-on module) | pchoopanya | FLUENT | 10 | August 21, 2023 15:33 |
Abaqus - Fluent Coupling WITHOUT MPCCI | s.mishra | FLUENT | 1 | April 5, 2016 07:47 |
Density problem in fluent | flow_CH | FLUENT | 33 | December 15, 2013 07:49 |
Setting Density for Velocity Inlet Face | arkie87 | FLUENT | 0 | November 7, 2012 16:15 |
Variable Density Function | ryzd | FLUENT | 1 | August 25, 2011 15:16 |
