Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Fluent particle data file resets
Old   September 21, 2015, 20:45
Default Fluent particle data file resets
hwet is on a distinguished road
Hi
I am using a cluster for a DPM simulation. The particle data file which is written increases in size after every time step (which i suppose means that it is being updated correctly) but by the time the simulation finishes and a data file is written for some reason the particle data file only gives the particle data for the last time step and reduces in size from (100s of KB) to a few KB.
I was using the same setup before and all was good (i got the particle tracks for the whole simulation not just the last time step). Wondering if it has got to do something with the particle data file size? If I do a few timesteps (eg. 100) the particle file is OK but doing it for (eg 1000) timesteps it resets at some point which I dont know since I cannot keep an eye on the file for (8-10) hours which the simulation normally takes.
hwet is offline   Reply With Quote
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
