Non-zero phase-1 backflow through pressure outlet |
September 13, 2015, 08:07 |
Cees Haringa
Hi all,
I have a problem. I run a 2 phase bubble column. The top consists of a freeboard region with only gas. The top boundary is a pressure outlet, backflow is specified to be 100% phase-2 (gas). (I have reasons not to use a degassing outlet). Still, water accumulates in my freeboard region, until the tank is 100% full. Turns out the massflow of water through the outlet into the domain (backflow) is about 1 kg/s, even though I specified it to be 100% gas. Is anyone familiar with this problem and how to solve it? |
September 14, 2015, 04:06 |
Cees Haringa
I still have no idea where the problem originated, but switching from pressure outlet to pressure inlet significantly reduces (albeit not completely removes) the creation of phase-1 at the boundary.
It's at least reduced enough for the flowfield to reasonably converge without filling the whole tank... |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 11:34 |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 13:23 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 11:40 |
simple model, difficult outlet | Eric | CFX | 7 | May 23, 2014 09:13 |
Modeling transient negative pressure (suction pressure) in outlet | N_mrtz | FLUENT | 1 | July 18, 2013 21:59 |
