Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Difference between "Phase 2.Volume Fraction" and "Phase2.Mass Fraction"
Old   September 13, 2015, 05:26
Default Difference between "Phase 2.Volume Fraction" and "Phase2.Mass Fraction"
Jordi Pina
jpina is on a distinguished road
Hello!
I've carried out a 2-phases simulation where a melted polymer enters into a mould with air and, once studying the results with CFD-Post, I've realized that I can make the contours of Phase 2.Volume Fraction and Phase 2.Mass Fraction.
It turns out that both contours are similar but slightly different.
Could someone explain me the difference and why are they different?
Thanks in advance!
jpina is offline   Reply With Quote
Old   September 13, 2015, 08:25
Cees Haringa
CeesH is on a distinguished road
They are only equal if the density of both phases is equal.
As an example, consider a container where 50% of the volume is filled by solid steel, and the other 50% by a perfect vacuum. Then the volume fraction of steel in the container is 50%. The mass fraction of steel is, however, 100% because the vacuum has 0 density.
In your case, the density of the phases is nearly equal, but not exactly.
CeesH is offline   Reply With Quote
Old   October 28, 2015, 02:33
Default Cryogenic systems
Hambli Amine
Amn.doc is on a distinguished road
Hi every one
My problem is how to inject the liquid phase of Oxygen under high pressure and
low temperature, then I can start the simulation even without combustion;
That set.
Thank you a lot in advance.
Amn.doc is offline   Reply With Quote
