September 6, 2015, 02:29 |
Three fluids in a container
Peyman
Rep Power: 13 |
Hi everybody
I want to simulate the water droplet in an air-oil container. This problem is transient and i can not apply 3 fluids (water, air, oil) in the fluent software. can you help me about this problem? Thanks in advance Peyman |
September 6, 2015, 08:10 |
Amin
Rep Power: 15 |
Hey,
I guess you should use VoF model and also you'll need a UDF in order to control the droplet injection... |
September 7, 2015, 05:29 |
#3 | |
Peyman
Rep Power: 13 |
thanks for your answer. I have been used the VOF model but i can not model 3 phase (Water, air, Oil) with it. can you tell me how can i model 3 phase fluids. best regards Peyman |
September 11, 2015, 05:31 |
Peyman
Rep Power: 13 |
anybody can help me?
thanks |
September 12, 2015, 13:05 |
#5 | |
Amin
Rep Power: 15 |
what's your problem exactly? Have you patched the oil domain? have you set the inlet boundary condition as water? |
September 13, 2015, 02:31 |
Peyman
Rep Power: 13 |
Hi amin
In this problem the water drops into a container that contains air and oil. Tempreture of the water is lower than the oil. As you see in the picture, the water droplet falls into the oil. The inlet of this problem is defined by a UDF file with swinging velocity. I used VOF model, but i could model only two phases (water and air). The oil phase not modeled and i do not know how can i do it. Thanks Peyman |
September 29, 2015, 08:30 |
Rep Power: 12 |
Then you could try using Eulerian model, instead of VOF. I dont have an expirience with this model, but you should be able to simulate more than 2 phases with it. The only limitation for number of phases is convergence and HW limitations.
two mixing compresible fluids solver | ziemowitzima | OpenFOAM Running, Solving & CFD | 27 | August 13, 2020 13:40 |
Permeability filling of container outlet condition | unoder | OpenFOAM Running, Solving & CFD | 21 | June 2, 2014 13:21 |
Mixing of fluids in a container with a rotor | crippled | ANSYS | 0 | April 17, 2014 07:49 |
Emptying a container suddenly? Is there a name for this topic? | bzz77 | Main CFD Forum | 0 | August 21, 2011 08:57 |
Differents fluids separated by wall | phil | FLUENT | 0 | January 18, 2007 03:43 |
