Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Problem with Pressure Outlet and Openchannelflow
Old   August 31, 2015, 06:25
Default Problem with Pressure Outlet and Openchannelflow
Sebastian Bock
sebebo is on a distinguished road
Hello CFD Online,
i am simulating a simple openchannel problem, but the pressure outlet i use acts like an inlet and i am not able to find the cause. I uploaded the cas file, in the hope that somebody can help me.
sebebo is offline   Reply With Quote
Old   September 29, 2015, 09:56
landerfwc is on a distinguished road
I have several notes to your case:
- too coarse mesh. I mean, 400 cells? You should make much finer mesh to get some reasonable solution.
- when using k-epsilon model, the good "fisrt choice" can be Non-equilibrium wall function
-as a surface tension you have used value 72 N/m. The actual value is 72 mN/m - 1000x smaller.
What problem are you trying to simulate?
landerfwc is offline   Reply With Quote
