August 26, 2015, 17:47 |
Volume fraction cutoff
Mohammad
Rep Power: 11 |
Hi
I have a question about volume fraction cutoff. What is it exactly? Is it related to accuracy of the solution? Thank you |
September 29, 2015, 10:06 |
Rep Power: 12 |
See The Fluent Manual:
The Volume Fraction Cutoff allows you to specify a cutoff limit for the volume fraction values. The value that you provide is used as the lower cutoff for the volume fraction. All volume fraction values in the domain below this cutoff value are set to zero. The upper cutoff is calculated as (1.0 - lower cutoff). All volume fraction values above the upper cutoff value are set to 1.0. The default value is 1e-6, which is the recommended value. Using a higher value may lead to a higher volume imbalance. Important: The Volume Fraction Cutoff value can be specified when using the VOF model, or when using the Eulerian Multiphase model with the Explicit formulation. Note: For the Implicit formulation, the minimum value allowed is 0 and the maximum allowable value is 1e-6. For the Explicit formulation, the minimum value allowed is 0 and the maximum allowable value is 1e-4. A higher cutoff value is available with the Explicit formulation because it allows for the local redistribution procedure of partially filled cells, which accounts for volume loss. This treatment is not available with the Implicit formulation. |
DPM volume fraction and phase 2 volume fraction | wkqwkqwkq | FLUENT | 0 | May 14, 2015 06:37 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
interDyMFoam - change in volume fraction | gopala | OpenFOAM Running, Solving & CFD | 0 | April 27, 2009 11:46 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 22:14 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
