Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Multiphase (water drain)
Old   August 13, 2015, 19:40
Default Multiphase (water drain)
Darthv
darthvader is on a distinguished road
I am simulating a simple problem in which water is being drained from a vessel. I have defined the boundary conditions as pressure inlet and pressure outlet at inlet and outlet respectively. So, air is supposed to gradually get in from the inlet as water comes out.
But, it seems to be happening that the water on moving out is creating a vacuum causing air to flow in from the outlet.
I have specified at inlet Volume fraction of water entering to be zero, but cannot specify air to be 1. is this causing the problem?
I patch half the vessel with water before starting the simulation.
Kindly help me..
darthvader is offline   Reply With Quote
drainage, multiphase, vacuum
Mass imbalance problem in multiphase water and steam CFX case Antech CFX 1 October 26, 2020 05:03
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Multiphase model, water disperses in air bugra Main CFD Forum 1 January 30, 2010 11:57
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
