Modelling the two-phase flow Pressure Drop in a helical coil |
August 11, 2015, 08:08 |
Andrew Vella
Rep Power: 11 |
I am trying to measure the two-phase flow pressure drop in a helical coil as a function of the coil geometry and the flow properties such as the velocity.
Therefore, I would like to question the use of the Operating Pressure (Operating Conditions tab) in Fluent. Hence, if we specify the inlet velocity and the outlet gauge pressure, what about the Operating Pressure? Should this be equal to the outlet gauge pressure plus the atmospheric pressure? Thanks in advance for your assistance! |
August 11, 2015, 08:36 |
Rep Power: 13 |
August 11, 2015, 09:03 |
Andrew Vella
Rep Power: 11 |
Many thanks for your prompt reply! However, things are still not 100% clear. I have an experimental measurement of the total system pressure at the flow line of a helical coil of 201325 Pa (Gauge). Hence I used this as the pressure spec on the pressure outlet. I need to calculate the initial pressure and hence deduct the total flow pressure drop between the inlet and the outlet. Therefore, if a specify an operating pressure of 30125Pa (Absolute) would this work
August 11, 2015, 18:36 |
Rep Power: 13 |
per my understanding that should work as your measured pressure is the pressure drop, which is irrespective of inlet and outlet pressure magnitude.. you could try nevertheless..
August 12, 2015, 05:49 |
Andrew Vella
Rep Power: 11 |
Thanks a lot. Things are clearer now. I will have a go and will get back to you if I'm stuck... Thanks
pressure drop and two phase problem | omaralyahia | CFX | 1 | July 16, 2015 19:01 |
total pressure and pressure drop | omaralyahia | CFX | 5 | July 14, 2015 09:13 |
Pressure contours in two compressible phase flow | Hershey | Fluent Multiphase | 1 | June 6, 2014 08:41 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
incompressible flow - prescribing pressure drop - how best to do it? | M. Gerritsen | Main CFD Forum | 4 | January 10, 1999 10:53 |
