Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Separated flow and multiphase in the same analysis?
Old   July 24, 2015, 15:07
Default Separated flow and multiphase in the same analysis?
Ignacio
authent is on a distinguished road
Hi everyone!
I'm new at setting multiphase cases. I'm trying to simulate a pipe with a water-vapor mixture on the inside and any gas (air, co2) on the outside.
A similar case would be a double pipe heat exchanger.
It's important to say that there's no mass exchange, they are separated domains (zones).
The problem is that when I define the multiphase water-vapor mixture, I'm allowed only to use that mixture for all the fluids in the cell zone settings, excluding my precious cover gas.
Thank you in advance!
authent is offline   Reply With Quote
Old   July 31, 2015, 11:35
Cees Haringa
CeesH is on a distinguished road
Split the domain in 2 zones in your meshing editor, using a named selection to specify each zone. Then, you can set conditions separately for each zone under 'cell zone conditions' in FLUENT
Best,
Cees
CeesH is offline   Reply With Quote
Old   July 31, 2015, 14:36
Ignacio
Thank you CeesH, but splitting the model into 2 or more zones won't help. As we did a little research, came up with this:
http://www.sciencedirect.com/science...17931012008174
The author states that "As stated in the FLUENT user’s guide, in modelling heat transfer in two separated fluid regions involving multispecies, only a single mixture material for the entire domain can be used." [3. Solution procedures - pg. 713]
materials, multiphase, separted domains
Calculating mass flow rate at multiphase flows Kuslo187 OpenFOAM Post-Processing 1 August 21, 2015 19:11
Difference in flow distribution of single phase and multiphase analysis shivasluzz CFX 0 April 22, 2015 23:54
Fluent v15 multiphase flow b.c. failure Non-channel flow mickjazz Fluent Multiphase 1 September 22, 2014 07:41
Some quiestions on multiphase flow fjalil CFX 4 June 17, 2009 13:32
Multiphase flow modeling Paul CFX 2 August 11, 2003 10:41
