Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Time delayed input for multiphase model in Fluent
Old   July 16, 2015, 16:08
Default Time delayed input for multiphase model in Fluent
Rakibul Islam
Rakib is on a distinguished road
Hi
I am a beginner in Fluent. I am working on multi-phase (water and air) model where water and air are coming to a vessel from two different direction and different path. I know the mass flow rate at the inlets for water and air. In my case water is injected 7 seconds earlier than the injection of air. Is it possible to to provide any time delay between the two inputs? If it is possible , any help regarding time delay input will be highly appreciated.
Regards
Rakib
Rakib is offline   Reply With Quote
Old   July 17, 2015, 09:41
Robert Strong
strongrj13 is on a distinguished road
If you want to get into doing it automatically you can write commands to turn on the air after so many time steps or you just run it with just the water for 7 seconds and then turn on the air manually.
strongrj13 is offline   Reply With Quote
Old   July 17, 2015, 19:50
Rakibul Islam
Thanks Robert for your guideline. The second procedure would be easier for me compared to the other one. If I am not wrong, I guess for the automatic procedure you are referring to UDF (Define Macros).
Elastic or Plastic Deformations in OpenFOAM NickolasPl OpenFOAM Pre-Processing 36 September 23, 2023 09:22
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Hardware-Configuration for Fluent HPC-Pack (8x) JohHaas Hardware 9 March 3, 2015 14:25
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
